Arma II: Operation Arrowhead
Publisher: IDEA Games
From our
Operation Arrowhead Review:
Operation Arrowhead is still a massive challenge for any PC to play smoothly, so you should forget about running it on maximum settings. Bohemia Interactive claims to have optimised things for Arrowhead, but we didn’t find that it ran any faster than Arma II. This is a great shame, as when maxed out, Operation Arrowhead’s guerrilla-infested mountains are simply breathtaking to behold.
Operation Arrowhead doesn’t fundamentally change the gameplay of Arma II, so it’s still a very unforgiving mil-sim. If you’re expecting to run and gun and live then forget it, in a mil-sim such as Operation Arrowhead you have to think like a soldier to survive.'
We test this hugely demanding game at its most challenging settings, with all the detail options set to Very High and High anti-aliasing enabled. For the benchmark itself, we use a 60-second FRAPs run performed within our own custom timedemo. As the benchmark is variable due to AI inconsistencies, tests are performed three times and the average result is used.
*Arma II has recently been updated to version 1.59, and we're in the process of re-testing cards using this new version. This is why all the cards aren't listed in the graphs below*
Nvidia GeForce GTX 590 3GB
AMD Radeon HD 6990 4GB (overclocked)
AMD Radeon HD 6990 4GB (stock)
PNY XLR8 Liquid Cooled GTX 580 OC 1.5GB
Asus Matrix GTX580 Platinum
Nvidia GeForce GTX 580 1.5GB
Nvidia GeForce GTX 570 1.3GB
AMD Radeon HD 6970 2GB
Gainward GeForce GTX 560 Ti Golden Sample
Nvidia GeForce GTX 560 Ti 1GB
KFA2 MDT X5 GTX 560 Ti 1GB
Zotac GeForce GTX 560 1GB AMP!
Gainward GTX 560 Ti 2GB Phantom
KFA² GeForce GTX 560 EX OC 1GB
AMD Radeon HD 6950 2GB
AMD Radeon HD 6950 1GB
AMD Radeon HD 6870 1GB
AMD Radeon HD 6850 1GB
Nvidia GeForce GTX 550 Ti 1GB
20
30
40
50
60
70
80
90
Frames Per Second
20
30
40
50
60
70
80
90
Frames Per Second
Read our
Performance Analysis.
